cars running tens on iron heads
malibuick231
Those of you running tens on iron heads what kind are you using or who done your work. Thanks for any comments and help.
Been running 10.60's with stock iron heads for about 5 years or so. Derrick from Precision Turbo did them about 5 years ago. Bigger valves, 18lbs boost with pt 70 4 bolt turbo, 83lb injectors, full weight car with no fiberglass. BTW, Derrick is now the crew chief for Warren Johnson (prostock)
Joe
