Ok so here it is. First off I have and 87 GN with mods listed below in the signature. Secondly I have read Julios chasing knock write-up (very-good!!)about a hundred times and have takin many of his suggestions but I am still havin a hell of a time... So I just recently parked the ride in the shop and took it all apart. The information I ended up with is this. After a very thorough compression test I got 130psi on each cylinder. Each plug that I pulled looked nice and tanish black but not terrible. Some of their threads had a little bit of oil but not alot. Next I pulled all old intake couplings and replaced them with brand new silicone couplings to eliminate any excess air coming in. I than proceded to clean the intercooler and leak test it. It held 40psi with no leaks and no water leaks with standing water in it so that is good. I also replaced the following sensors with ACDelco parts because they previously were not, Knock, TPS, O2, and the bottom half of the coil pack. The MAF is an original and seems to be ok. After doing all this I took the car for a run and I am still seeing kncok. I cannot hear any knock at all which is strange but when I drive the car and I boost at about 2-3 psi I start to knock up to about 5-6psi (I let off after that) and it goes like this... 0.0 .04 .07 1.4 3.4 4.0 4.9(4-5psi) (let off gas slow) 4.0 3.6 2.5 1.7 .09 .03 0.0 Another instance while I was trying to figure out what is going on I boosted to about 5psi and got up to 9.4 degrees knock in a similar pattern as before. As you probebly know this is irritating the S**T out of me. I have no idea what it could be. There are no wires bouncing around back there because I ty-raped them all so they wouldnt, and the huge kicker is that when I ran 104 at the track a little while ago i had NO KNOCK at all, all day long which just confuses me even more. If it dosent knock with high octane why the hell is it now with methanol and at such low boost?? Could it be a bad ESC and if so where is it and how do I replace it? I just put julios kit on and it still knocks. Someone PLEASE help me I am so sick of this. I just want my car to be ok and I WANT TO BOOST. I miss it.
:frown:
