Dan Thompson
- May 25, 2001
Would Casper's Quick Start Module that is inserted into the cam sensor wiring determine if the cam sensor is bad?
My car will not start and back fires when I try to start it.
The cam sensor rotor and cup look just fine. The cam sensor is clamped tight and does not move and the cup only as a very small amount for free play, about like a distributor rotor. So I thought with the Quick Start Module in place, if the car started the problem must be the cam sensor.
Am I on the right track?
