Info:
Hello... :smile:
So far Carl's SkyHawk is going well and I'm about ready to find out exactly what needs to be done with the actual fitment of the turbo buick engine.
As Carl stated the rear end and torque arm is a issue if your going to put any kind of power to it. I like the South Side Machiene lift bar setup that "was"
avalible for the 82-92 Camaro's which elimiates the stock torque arm and lower controll arms. I then put coil overs in the back of the rear end and a pan hard bar. The same basic setup would work great on your car/s.
We are still debating on what to do with Carl's rear end. (no pun intended)
Anyway.. with the engine bay I'm going to make a tubular front memeber (go's from the radiatior support to the cross member)
The stock one is flimsy and takes up way too much room.
The cross over pipe from the drivers side header to the pass. side header won't fit with out cutting into some of the supporting metal on the pass. side unibody. I'm going to take exact pictures of what I did to make it fit and how I brace everything.
I could make another front member if your intersted when this one is finished.
The Down pipe is not going to go in the traditional route. There's just no room. It'll have to go down under the front suspension and then to the exhaust. We are planning on useing 3" oval tube for that.
THe stock fuel tank will work fine. I took his stock fuel sending unit/pump out and installed the Warbro 340 with a few small mods to make it stay in place
and installed a vent line for the Charchol canister (which I'll relocate to the rear by the tank)
I'm going to use two stock GN intercoolers welded together and make it a front mount. We did this on a hybrid Camaro and it cooled better than a CAS front mount for the TTA that we had in another hybrid Camaro that cost 1200.00!!!
Chris and I just finished a Mustang Hybrid that included moving the firewall back 3.5" shaving the strut towers, welding every hole in the engine bay and painting/bodywork the entire car.
We can actually take the dipstick tube out of the tranny from the top with ease! That's how much room there is around the bell houseing area!
This car is going to be a snap to do any work on.
Spend a little extra time moving things around so they can be worked on later.. saves alot of frustration down the road...
Anyway.... I've got some pictures of the fuel system that I've done and I'll have alot more to come here in the next few weeks as the project moves forward...
If I can help just let me know
Scott~
