Chip Hints
Thanks For Your Expertise, Time, & Effort!!
Thanks for all your contributions, bruce!
Your article on gnttype.org is a great reference.
______________________________________
Question regarding equipment:
What is involved in going to a WB ?
(Parts, install, typical costs, etc)
The Jan. '03 GMHTP has an article stating the factory
02 sensors are only accurate at precisely 14:7 AFR, whereas
the WB is accurate to 3-4 points on either side of stoichometric...which no doubt saves HGs & motors, in addition to bringing the combo much closer to optimum efficiency.
Their system:
Accel DFI Gen 7 $1422.00
WB 02 option $951.00
Jumper Harness $738.00
Parts = $3111.00
_______________________________________
I do thoroughly see the benefits & improvements of
such a system, but, I'm certain its expense will keep many from using it.
Is there any way to reap any of the benefits of a WB set-up
on a lesser budget?
________________________________________
TIA as always! :)
Re: Thanks For Your Expertise, Time, & Effort!!
The Jan. '02 GMHTP has an article stating the factory
Parts = $3111.00
Go to WWW.DIY-WB.COM
For $160 you can put one together.
If you go for the fancy LED display you can still get out for under $200.
Be advised there are pirated versions available, and they are poorly designed copies of the American Version at the above website.
Anderson Motor Sports claims to have one for $550 that is assembled. The FJO one is also a non pirated version for closer to $700.
