Click Clicking noise
artrenee10
Older...wiser...and broker...
Click Clicking noise when I try to turn on the car, cannot determine if its starter or alternator. BTW what alternator and starter are you guys running? Not a race car just trying to be a low 12 high elevens right now. Everything pretty much stock.
Thanks Guys
Steve chambers
if you turn the key, and it just clicks, jump start the car. Then check your voltage and make sure the alternator is charging. You can also jump the car, so it is running, then disconnect the battery. If the car dies after that, the alternator is toast.
