Code 22 after a new TPS and iac reset
turbowrenchhead
Drive like you stole it!
I put a new tps on becuase I could not get 4.65 at wot. I was getting code 21 and 22 from the old tps as well. It was a new delco unit maybe 2 years old with 1k miles on it. So I bought another tps and sloted it to get the correct volts. I went throught the IAC reset and and set the tps with key on engine off to .42 at idle. I went through the reset twice and I 'm still geting a code 22. Something else I noticed is that with the dvom reading the tps when running that the voltage drops to .16 or so at idle. But yet I get tps circuit to high code, doesn't make sense. Unless I have my codes mixed up.
There was a thread recently here or "over there" (********, can I say that?) where a guy has been chasing a tps issue for months. I think he found just a week or 2 ago that the wires were crossed and in the incorrect pin in the tps connector. Justa thought.
edited:
bwahaha, I can't say it!!!! unbelievable!
backwards, maybe??? moc.skciubobrut.www
I don't think the wires are crossed becuase when I got a new connector with the turbomotion intake and 87 t/b it worked find without any problems. Not till recently I have been having tps problems.
You say you got a new connector? Do you mean a new one that plugs into the TPS? If so, maybe it's flaking.
I'm going to check the wires next. I also have another tps to try to see if it does the same thing.
