code 34
shawnz
Dummy me went and shampooed the engine without covering some of the vital parts .Now i get a code 34 with black smoke out the tail pipes and the oxygen sensoe is reading only between 200 and 330 .I dried out the maf reset everything and was fine for a while but threw another code 34! any ideas do i need a new maf
CODE 34
Trouble Code 34 indicates that the Mass Air Flow (MAF) sensor is reporting less air is entering the engine than makes sense based on RPM and TPS. The MAF sensor produces a frequency output; around 30 Hz at idle to 150 Hz under acceleration. The frequency varies proportionally to airflow. The ECM monitors the frequency and thus determines airflow into the engine. Typical idle MAF is 5 to 7 grams per second.
The conditions for setting this code are:
no Code 21 or 22 (TPS Error) present, and
the air flow reported is < 4 grams per second, and
TPS indicates 10% or more throttle position, and
the engine speed is 1800 RPM or higher, and
the above conditions exist for over 5 seconds.
Typical causes for this code include:
1) Faulty air ducting to or from MAF sensor
2) Faulty ECM-to-MAF connections
3) Poor routing of MAF harness (i.e. near coil packs)
4) Maladjusted TPS sensor
5) Defective MAF sensor
6) Defective ECM
