comp 979 springs
grass doctor
Dream Catcher
TurboBuick.Com Supporter!
who carries these springs or does anyone have a new set I could buy
I have a new set of 980-12's ... if your running any boost don't bother with the 979's .. your talking roughly 10 pounds on the seat difference
after a few heat cycles your probably right at stock levels
10/4 thx for that info I have 980's just scared in my older motor/cam
Then change the chain , put an upgraded valve spring in it and move on.
If your going to neuter it .. pull the chip off and all the other mods and do it right :)
You are fine with putting 980’s on stock cam and lifters. Your lifters are hardened and broken in already. I wouldn’t put less spring than 980’s. It just wouldn’t be worth the time it takes to do it. Many of us put LT1 100# springs in back in the 90’s without any issues. As long as you realize flat tappet cams require good oil that’s high in zinc and don’t try to run mobile 1 or other thin synthetic oil you will be fine.
10/4 I run brad penn oil and half a bottle zddp as the brad penn I s already high in the good stuff
