steve hughes
- Jul 5, 2002
I used the comp lifters that came with it. I got the cam from Cotton. Part # 69-246-4 grind #dv6 268h-10 . It's the same # Slusser is running. My lifter preload is about .030. I'm using the stock springs that came on the GN1's . I had a valve job done on them a few months ago and they came out to 100 lbs. on the seat.
I'm running a DFI . No chip. But if i were running a chip it would be the Maxeffort mafless.
The car is very responsive except for a slight just off idle flat spot. I don't believe it has anything to do with the cam. Just needs more tuning on the dfi.
