Sep 26, 2012 #1 B buick rob New Member Joined Aug 25, 2012 Messages 8 I have the 979s new inthe box or should i go with the 980s ? Stock cam 30k on the originals . Thanks again Robert E.
Sep 27, 2012 #2 F forcefed3.8's Buckeye Bullet Joined May 26, 2002 Messages 3,845 979's with the factory cup.
Sep 27, 2012 #3 B buick rob New Member Joined Aug 25, 2012 Messages 8 Ok thanks , alot of vendors kept saying i needed the 980s instead to make any difference.
Sep 27, 2012 #4 B bison Moderator Staff member TurboBuick.Com Supporter! Joined Dec 19, 2005 Messages 18,053 buick rob said: Ok thanks , alot of vendors kept saying i needed the 980s instead to make any difference. Click to expand... 980's need a lot if shimming to get a decent pressure. I would use them on a stock cam only. Aftermarket cams need more sping.
Sep 28, 2012 #5 F Fast4Ward Well-Known Member Joined Mar 27, 2005 Messages 1,162 the 981 's and Sealed Power VS739r are one step above the 980's at 105 pressure install height of 1.7 i'll be changing them out once breakin is complete with the 980's.
