Compressor "Tout" - Need mathematics help
Use a calculator that has a Y to the X key.
punch in 2.373, hit the Y to the X key and then punch in .263.
Sorry I don't remember how to type Y superscript X here. :)
Don't have one. :D
I did find this, however: http://www.scientificcalculator.com/, but I would still like to know how it works. I am trying to put the entire calculation on an Excel spreadsheet so that I can plug in different values and see the data.
:-Dean
well, using that calculator-
punch in 2.373, then hit the Y to X key, then punch in 0,263 and hit the equal key....should get 1.255 and a bunch more decimals.
Then do -1 + 1.255= 0.255/.72 which = .354
Then .354 x 530 = 187
Finally 530 plus 187 = 717
Now, if you want me to tell you how to do exponents in Excel, it has been too long and I am sure there is a spread sheet guru around here that do it quicker than I can relearn it! :D
Hey, I can do that! You need cells A1:B6
  • A1: type in Tin:
  • A2 type in Pout
  • A3 type in Pin:
  • A4 type in efficiency:
  • A5 type in Tout:
  • A6 type in (formula) =B1+460
  • B1 user to enter value for Tin
  • B2 user to enter value for Pout
  • B3 user to enter value for Pin
  • B4 user to enter value for efficiency
  • B5 type in (formula) =B6-460 this will be youy computed value for Tout
  • B6 enter (formula) =A6+(A6*(-1+(B2/B3)^0.263)/B4)
It's not "pretty" but you can add on from here.
S10xGN, that's kinda what I'm doing, except also all the calc's to get all the necessary points (n, V, P/psia, T/Tin, etc.) computed by just inputing the known data variables (CID, Max RPM, Atmospheric temp & Pressure, etc.). The POWER(number, power) takes care of the current hurdle... we'll see what's next. :)
:-Dean
Hehehe... yeah, just saw that ~5 minutes ago.
I got to reading it, got lost due to not understanding the calcs, and started putting calcs together to make me understand. it was a great learning exercise. :)
Thanks,
:-Dean
