Control Arms??????
TMGN
Time to tackle the suspension.Which upper and lowers are you running?Which do you recommend?BMR?HR?Sway bars? I will be driving on street but want a bad drag car.Thanks
I'm running some Hotchkiss lower control arms, along with some Pro Traxion adjustable upper ones, all this with an H&R sway bar and Kenne-Bell pinion snubber... The only complaint I have is that the upper control arms have some solid steel bushings ( rod ends ) at one end causing some noise and a harsh ride when driving around. I'm going to have them replaced with Hotchkiss upper adjustable ones with urethane bushings at both ends which should solve the problem. These Pro Traxion upper control arms were meant to be race-only pieces...They are very nice but not ideal for a street driven car. I have a few pictures available too!...
'bye,
Claude :)
tHAT SOUNDS LIKE A GREAT COMBO.i WOULDN'T MIND THE NOISE.PLEASE SEND PICS.THANKS AGAIN.
I have the Hotchkis lower arms with air bags in the rear springs and cheap "bouncy" monroe shocks at all four corners. Haven't replaced the upper arms yet. Pretty good street ride for the most part but I'll probably go for some adjustable Hal shocks at some point.
