Coolant turbo lines
2nd chance GN
Curious who's using what for coolant lines, I tried the search option. I removed my heater box and the lines use to run thru that hard line. No longer using that, trying to figure out how to run it. And pics would be great. Thanks
Are you referring to the water cooled center section style turbo? If so I ran supply to the back side from intake and return from front side back to water pump. (No heater hard lines)
Take a look at the att." Garrett White Pages" for some info on how these are cooled
One line comes from behind the thermostat and the other after so there's positive flow at all times going to the pump inlet is the best spot for the return. Just like the heater
BPE2013@hotmail.com
