Tom87GNX
- Nov 29, 2012
Hey fellas I have no cooling fan operation, I have constant 12v from starter solenoid at relay connectors, and jumping the power to the fan proves the fan works. I don't have power at the brown wire on the relay connectors which is 12v ignition on which should be powered from either A/C fuse on 86 models or relay fuse on 87's. Has anyone run into this issue? The a/c fuse is good (I don't have a relay fuse or slot in fuse block) is there a connection somewhere else or factory splice pack? Any help would be greatly appreciated. Btw, I'm following the schematic from vortex buicks. Thanks in advance
Tom
Tom
