CPP Gbody Spindles for C5 Corvette brakes
V6UnderPressure
The Artist FKA Scott4DMny
Brand new just released. Uses the C5 caliper and rotor. I have two sets. $260 each pair shipped to your front door. PayPal as friends/family only or pickup in Chicago area.
What size wheels would be required to clear the brake calipers
What are the benefits of these vs blazer spindles and hubs?
Well for one the C5 rotor is much larger than blazer rotors. C5 calipers are also aluminum. Way lighter than the blazer caliper. I can’t answer the question about the hubs. They both have similar style bolt in sealed bearing hubs.
Im sorry, I didnt explain my question correctly. I have blazer spindles and hubs with C6 14” rotors and 6 piston calipers. I was wondering what type of advantage vs what I already have.
Other than larger C5 sealed bearings and the fact the spindle is much beefier than the blazer one, I really don’t think there’s that much advantage to switching. If you’re using the kore3 brackets now, I guess you also wouldn’t need the shims which may or may not be an advantage.
Here they are.
Very interested, is there somewhere I can read more about these? I've been out of the game for a while, so excuse my ignorance on these.
Thanks!
Zack
