- May 28, 2001
Suggest care be taken when using a high level of evac vacuum. Too much, and the cyl walls go dry, and the wrist pins are subject to galling.
SignUp Now!Suggest care be taken when using a high level of evac vacuum. Too much, and the cyl walls go dry, and the wrist pins are subject to galling.
Can the electric pump handle pumping liquid or do you need some sort of seperator between the valve cover and the pump?
Additionally what were the thoughts of running to of the GM electric pumps?
I found this setup on a corvette forum. I wasn't sure how to post a link so I copied the picture. Very tidy setup that sits on the battery tray. Apparently the pump he used is from a BMW.
I don't think you want to run alot of liquid through the pump. I recommend a catch can.
Since my car is primarily street driven and my reading has led me to believe the electric pumps won't live if you run them all the time... I am thinking about hooking the pump up on a hobbs switch and maybe using some sort of solenoid on the pcv... so that when the hobbs switch turns the vacuum pump on... the solenoid will close the pcv off.... and not let any vacuum through the line going to the throttle body.... should cut way down on oil suckage while under boost....
Now.... to find a good solenoid type valve that has a good enough flow rate for the stock PCV system.
Any thoughts?
How are you guys measuring vacuum? Hopefully not at idle, must be measured under full boost under load when there is the most blowby.
If you have no AC, this is my set up (page 2 shows a completed pics)
Crankcase evacuation pumps - t6p.com - Turbo Buick Regal Resource
Billy T.
gnxtc2@aol.com
