crappy shifts on a new everything tranny
hwfstru
I had my transmission rebuilt by a local tranny shop in my home town about six months ago and thats where my troubles started. I had the trans rebuilt with blue plate and high friction clutches, kevlar bands, 10 vein pump, hardened stator, art carr shift kit, trans brake, billet servo, 1-2 shift servo and all the hard parts. I got the tranny back in the car and took it for a test dirve and the thing wouldn't shift into any gear worth crap, the more throttle you give the car the softer it shifts. All the shifts are soft at anything over 1/4 throttle and they are anything but positive. I call the shop back and he tells me to adjust the TV cable and I do, with no help. Then he tells me to buy a new shift cable (mine was really ratty to begin with), no luck. He tells me that my motor may be torqueing to the passenger side pulling on the cable and patially closing the valve body, so I buy both poly motor mounts and the poly trans mount and it helps nothing. After all of this I take the car back to the shop and they take the trans apart again looking for any problems and find the 2nd gear clutches "glazed" so he replaces the clutches and the band and all the gaskets and o-rings and bolts it back up, didn't help anything. I just got back from picking the car up again from the same shop where they took it back out again and put my parts in a new transmission case because he believed that the old case may have had a hairline crack in it causing it to shift crappy with harder acceleration, that didn't help either. So you can see my frustration with this, I have spent the better part of six months trying to get my transmission to cooperate with the rest of my car and it is making me really angry. Help me please, I need it badly.
I dont know anyone in TN for trannies, but Mike Smith is a real good tech and is in Va, maybe he can help?
Did they use the gn/t-type valvebody?Or did they did they put a different one in there?
It still has the brf valve body from my transmission, he just took all my guts and put them in a new case. This guy is from the same town as Mike, Mike and I are from the same part of Virginia.
