There's a great list of troubleshooting ideas in the factory service manual.
Usual cause of inoperation is the brake electrical switch and/or the brake vacuum switch. There are 2 for the cruise.
Other failure modes are the wiring in the steering column and broken stalk switches.
Where are you located?
Cruise module is located up above the brake pedal on a shelf like metal tray that has a front tab you pull down to release the cigarette pack like plastic electronics box. One electrical connector to it.
Stalk plugs into a harness in that area also but not the box itself.
Looks like phone wire, 4 solid wires out of the stalk assembly with a flat connector on it.
