cutting out
ABLACK6
car runs great now, but after warmed up, at low speed it cuts out until i give it more gas, then it's great. Anyone know what causes that? all motor was cleaned already but still having that problem
1. Is the check engine light on when it stumbles, then go away when in throttle?
2. at idle, tap the MAF sensor with the back of a screw driver. If it stumbles, replace MAF.
ok thank you very much! I'll try that later. if it dont stumble when i tap it, any clue anything else it could be?
