No pics, but I have swapped an 84 GN dash into my '81 Elky. Drop the insulation panels underneath each side of the dash, and the wide speaker dash cover. There is about 6 or 8 9/32's holding the top of the dash to the firewall and there is a 10mm nut under the dash on each side. You will also need to drop the steering column as the two bolts that hold it up also hold the dash. It's not too bad of a job, just keep track of where each bolt/nut came from on disassembly.
