I'm trying to figure out if i have a dead fuel pump.
Was cruising on the freeway and all of a sudden car just died. Pulled over to the side of the road and called
AAA. They checked the alternator and tried jump starting to no avail.
I noticed that my fuel pressure gauge was only reading ~20psi when i had the ignition on. When i tried starting the car it struggled to turn over. When it did it would just die right away.
Shouldn't the gauge be reading ~40psi with the ignition on? Or does it need to be running to build the correct fuel pressure?
Other thing is i replaced to stock fuel pump with hotwire and walbro about 6yrs ago and about 10k miles
