NHRA Super Gas
- Nov 18, 2005
I have started to notice white smoke from the exhaust at startup and when I pull up to a stoplight. Car still seems to run good and strong, Idles a little high and BL is high after a chip change. I added a quart of coolant yesterday, promptly disappeared. Added another one that has stayed level, so that may have just been low. Also have wet black smudge forming on the exhaust tips.
I drained the oil last night, nothing seems out of the ordinary. A little gas fouled, but I chalk that up to Reds chip. I replaced with a Turbo Tweak just the other day. I pulled one plug and it was a perfect color. I probably need to check the rest.
I can think of three things, none of them good:
Intake gasket
Head gasket
Piston Ring/Valve seals.
This motor is very fresh, so I'm skeptical about the last part. Only caveat there is the motor was broken in with Mobil 1 synthetic, so I'm a little paranoid about the ring seat.
OK, now I'll continue my prayer "I won't try to go fast again without alcohol, I promise".........
Intake gasket
Head gasket
