Difference between non turbo and turbo Regal fuel pump sending units?
d0n_3d
Boost is good.
I'm going to be running a Weldon 2015 external pump and I still want to use a sending unit in my new sumped gas tank so that my VDO gauge in the GNX dash shows the correct fuel level. Is there a difference from the non turbo Regal fuel tank sending unit compared to the turbo cars? I'm not running a pump in there. Reason I ask, Inline Tube sells the 78-87 non turbo Regal sending unit for $115 while the turbo Regal sending unit is $289. All I will be essentially using the sending unit for is the float level.
The non-t....
were 2-brl carbs. w/o sumps. My guess would be the sender is the same. What happened to your old unit? Can you use it? BTW, if no one knows for sure, might give Brian a call/e-mail at gbodyparts.com. I'm sure he would know.
I still have my old one but the top is so rusty. I'd like to get a new one because everything else on the car is going to be brand new. If the carb one works, that would be a steal compared to the turbo version! I'm not using the fuel lines except maybe the middle one for a vent. I need to know if the wiring and connectors are the same...if they are, awesome!
Give brian a...
call, he might have them cheaper. 717-359-9692 :smile:
