I IronCityTurbo6 Member Joined Jan 4, 2005 Nov 30, 2017 #1 Like the title says. Is there any way to make a Scanmaster G(for classic fast or xfi) work with the sportsman xfi?
T TurboBob Resident mad scientist Staff member Joined May 24, 2001 Nov 30, 2017 #2 it should connect the same way the eDash would.
I IronCityTurbo6 Member Joined Jan 4, 2005 Nov 30, 2017 #3 The e dash has a 4 wire harness and a much different plug. I realize the S G has 4 wires also. I know you said you didn’t try it yet, but do you think you might be able to shed some light on which wire connects to which?
T TurboBob Resident mad scientist Staff member Joined May 24, 2001 Dec 1, 2017 #4 it should be pin1 - red pin2 - black pin3 - white pin4 - green
I IronCityTurbo6 Member Joined Jan 4, 2005 Dec 2, 2017 #6 Is there a way to run an e dash simultaneously with a Scanmaster G?
