bird
- Feb 20, 2003
hey guys! installed hood mounted fuel presure gauge. went for some test runs. on one walbro 340 at 17lbs of boost at wot fuel presure was steady at 58psi. whith both pumps(both walbro 340's) on at wot with the same boost, fuel presure is still at 58psi. if you turn the 2nd pump on at idle fuel preusure raises about 15lbs. why doesnt the wot reading go up when 2nd pump comes on ????? anyways i decided to bench test the pumps, noticed one pump is flowing a little more than the other and they both leak fuel at the electrical connector(where the two male plugs meet the plastic body of the pump) one pump leaks more and oddly enouph its the one that seems to be flowing better. is this normal????both pumps are brand new. anyone have a similar experience????
