Sorry, this is probably in some FAQ or the like (but I could not locate). Can I run a 275 50 15 on my stock '87 Turbo-T rim without problems (rubbing, too big for rim? Or, should I use the 235 60 15 drag radial size for these stock rims? In either case they are 26 inches tall; my concern is rim fit for the 275s. Thanks for the input.
Also, with worn MT ET Streets, my short times stink (2.1) and my stock car spins badly on the 1-2 shift. I am using 17 psi - should I drop to 13 or so psi? Thanks.
PE
PE
