dream a little...
bentwing2
Hi all. Looking for some guidence.If you had the receipe to make an 11 second t-type/gn from a low mileage stock one;and had $3000 to spend-how would you spend it? I don't have time to waste guessing and I'd appriciate your knowelge and expierience
Thanks for any replys,
Chris
Depends on vehicle weight, but:
Spring Cleaning
ScanMaster or Direct Scan for tuning ($250 each)
Walbro 340 fuel pump ($99)
MSD 50lb injectors ($300)
RJC power plate ($60)
Remove factory air box and replace with K&N ($30)
Port/bellmouth intercooler neck (free if you can do it yourself)
TA60 turbo (used: $400, new $750)
Comp Cams 979 or 980 valve springs ($80)
Custom burned chip for 110+ octane ($60)
10 gallons 110+ octane ($50)
THDP with cutout ($400)
28x10 slicks ($300)
2800-3000 stall convertor ($500)
Launch with 10psi and you'll be in the 11's.
