Drivers seat cushion
Sal Lubrano said:
Is there a company which makes the drivers bottom seat foam. Mine is all flat.
You can do what I did.... find someone that is selling just a passenger seat... or seat bottom.... I bought one on here about a year ago... for about $60 shipped.... (just pass seat bottom)... it was in real nice shape... and hadn't been sat in that much (like I would suspect most ones you will run across will be)..... I took my worn out springs sticking up through the worn drivers side bottom...and set it side by side with my purchased used pass seat bottom..... all I had to do was carefully fish a big nut up under the cushion for the seat pivot... I think.... cause the nut was spot welded on the wrong side now.... once I fished that nut up in there... I was able to reassemble it with the original drivers seat back..... just on the new used pass seat bottom..... walla.... low usage 1987 GN seat bottom.... matched the other interior great..... if I don't tell anyone about it that has seen my seats... they would never have known I did it....
Where there is an empty pocketbook and a will.... there is a way..... you just have to think "out of the box" ....
FWIW.... the seat foam is called a bun.... and it is as high as a cats back....
I have a drivers bottom seat with good foam- $50. shipped (also have two good seat backs). Sal, if you re in nyc somewhere i could meet you with it for $40.
