What did the carbon fiber shaft run and how much HP is it rated for and where did you get it?
Thanks,
Scott
$1000 It's not cheap. I figured buying exhaust systems and floorboards were just as expensive too.
This is the shaft I bought...
Taken directly from their site....
Precision Shaft Technologies, Critical Link™ Driveshafts
Carbon Fiber Driveshafts
The finest driveshaft available anywhere. Each driveshaft is specifically designed by our Engineering Department to optimize the characteristics of Carbon Fiber required in your special application. Passed SFI test at 2800 Ft/lbs torque. Prices range from $500.00 to $950.00.
"Our newest "Critical Link" Carbon Fiber Driveshaft for Drag Racing application is 3 3/4" diameter, a 50" driveshaft weighs only 6LBS - with 1350 series solid U-Joints add 3LBS and Slip Yoke add approx 2 1/2LBS."
Advantages of Carbon Fiber
Lighter than steel or aluminum.
Three times torsional strength of steel.
Torsional spring rate allows better tire hook-up.
Torsional spring rate allows smoother shifting.
Less shock load to the differential.
Eliminates or dampens high speed vibrations.
Reduces transmission and differential breakage.
Characteristics can be varied by changing the wind, angles or diameter. PST offers both steel and 7075 Billet Aluminum yokes.
In drag racing applications - a better 60 Ft. time.
ET's have been lowered in some cases by as much as .120.
In stock car racing better control out of corners is the result of the torsional spring rate.
In road racing smoother shifting and better durability of transmission and differential have been reported.
Tested on Cobra's at 180 MPH on Dyno with no vibrations.
A much greater safety factor - carbon fiber will return to a fiber and not create shrapnel under the car, as would aluminum or steel shafts.
