DS in Houston anyone?
Jerryl
Tall Unvaccinated Chinese Guy
Anyone with DS willing to assist to log a few runs?
Not sure what all it takes but willing to compensate.
Still tuning and would like a few runs logged to send for programming.
My DS setup is hard to remove. The box is stuffed under the dash behind the glove box. It's too hard to remove.
Do you have a laptop? I have TurboMeter and WinALDL w/ cable if you need it.
These products only log once every 1.25 seconds so you are limited as to what you will log.
Thanks for the reply.
I have a laptop, running XP-Pro.
Like I said, i have no idea what is involved in connecting DS. All the engine work is done on this car and not looking to go any furhter/faster.
Just need tuning done now.
I use an OTC4000.
I am more than happy to assist. Most DS users have their DS equipment tucked up pretty tightly under the dash. Mine is a pain to remove.
I do have two products that use the WINALDL port. You can use either. TurboMeter and WinALDL are both free and are both loggers.
You can do Google searches on them to read get more info.
Let me know if you need the cable. I have one.
Thank you!
Will it log fast enough to see why I get serious KR when I punch it?
I have tried 4 MAFS and everything else seems fine.
O2's drop to 0.300 when I punch it and WOT is at .830 Of course, OTC is not that fast. Yes I verified FP@WOT and the fuel pressure rises instantly if I crack the throttle.
TT is working with me but I would like to provide him some more info.
Jerryl if i can get my laptop up and running soon i may be of some help, but as of now my DS laptop says "no operating system found" so ill be looking for a hard drive, if i can find one ill bring it down and we'll hook it up.
Anything that connect to the WinALDL port only logs one frame every 1.25 seconds.
So, in a 12 second pass, that's only 9.6 logs or updates.
DS, on the other hand, logs 12 frames a second I believe. In that same 12 second run, it would log 144 times.
Let me know if you need my help. I believe JD states he can help you out on DS once his laptop is fixed.
justabuickv6 said:
......... Let me know if you need my help. I believe JD states he can help you out on DS once his laptop is fixed.
Just.......
Yeah, would REALLY appreciate some help if possible.
Let me know your availability .... I don't need to blow another HG or motor.
JD .......
Hope you get your HD issue corrected soon.
We still need to get together for a few beers. :biggrin:
Edit:
justabuickv6, You are invited for beers as well.
When are you going to be working on it again? I will come by if I can talk the wife in to letting me disappear for a few hours.
Work on it pretty much every day.
How about this weekend, Sunday??
Saturday is my Defensive driving course day. :mad:
