87GNcospg
Send your Donations
- Jun 23, 2003
I installed the dual fans from http://www.allstarperformance.com/product.htm?prod=720 and installed the racetronix harness.
i have a manual switch wired in. the switch is a single throw double pole switch so i have control over high and lo. the switch is wired to a ground, one wire going to green wire from high speed relay, and another wire to the correct green wire from the low speed relay.
first question. is the above fan just a one speed fan? because i tested it before i soldered everything in place and jumping either wire from the high/lo relay turns the fan on at the same speed.
i am also having a problem with the switch for the fans. the switch works fine until the car starts to get to normal operating temperature. past 170 or so. then the switch stops working and the computer will not turn the fans on either. i can shut the car off, let it cool down and the manual switch will continue to work. all the connections are good. i checked them over and over again. what would cause this?
