Duel Fuel Pump Wiring Question?
Whitettype86
Young William
I'm wiring up my Used duel Atr fuel pump system. And was wondering if its ok to run the second pump hot wire (+) to the Altenator? Or should I run it to the battery?
What I did was to run a single power source from the alt (fused on both ends) to the trunk area and attach it to a second fuse block.
This gives me extra fuses and power for other things I have back there.
Just one way to skin a cat.
Good Luck
It is intended to be hooked to the alternator and then has an inline fuse before the relay.
