I spent some time on the dyno Friday and came away with a few questions. The combo is an 87 GN with a 206 roller cam, ported heads, RJC PP, 62 mm TB, stock MAF, 3" THDP, MSD 50's, stock turbo, dutt mod stock intercooler, pump gas. The weather was about mid 90's with a slight breeze. We were testing a new boost controller so the boost was only 13 psi for almost all of the runs but some were a little less. Looking at the HP graph, it was going up pretty steep until about 4400 - 4500 RPM then it sharply dropped about 25 HP. Weird. We looked at all of the runs and it was very repeatable. We then started logging MAF numbers and once the MAF pegged at 255 (logging Tlink data also) it looks like the MAF reset to zero, pegged again, reset to zero, and ended up at some number around 200. We also did some steady speed runs at about 4 grand and it would run fine for the first few seconds but then begin to surge several hundred RPM. We couldn't log the MAF numbers but pretty sure that was the cause. As a result the best HP number was 275 at 4450 RPM and about 310 ft/lb torque. Not too bad considering low boost and low RPM potential but still WAY below par. My questions are does a normally functioning MAF reset once it pegs? Is this MAF toast? Has anyone seen this type of thing before? Options? Thanks for any help.
