This was an easy pump gas 14psi pull. It made decent numbers but not what we expected. It's an M&A headed motor, not stage II headed. There were timing issues with the Felpro. We need more research in the timing department. We were only able to get 14 degrees of timing as seen with a timing light. It was fluctuating between 9-16 degrees at idle. The question I have is has anyone seen a nearly perfectly flat hp (not torque) curve? This thing was flat from the stall of the convertor to our self imposed 6,700rpm cutoff point. Doesnt seem right to me, maybe timing? Also, the AF was 12.0. Any idea what could cause a flat "curve"?
