- May 26, 2001
As Eagle has stated, their Buick forged crank is internal balance.
To go with external balance like stock, about 100 grams would need to be removed each from front and rear counterweight.
If aftermarket rods [heavier than stock] are used, then weight will have to be added for internal balance.
The rod and main bearings need to be "fit" to the journals. The crank does not have rolled fillets, but a radius journal.
If all goes as planned, this motor will be installed and running next week for "field" testing!
It is going into a 10 sec. GN so it will be a good first example for us.
