Efi live turbo tune file needed
garyk1970
Electronics Moderator
Staff member
I just got my turbo Silverado running and need a good tune to get started. If anyone has one, it would be appreciated and I wouldn't mind paying for a unlocked tune. Here's my combo;
I would like a cos speed density tune.
Stock 35k mile 4.8 (2010 with vvt & dod delete)
Lingenfelter 58x module to make old 2002 ecm work
Ls9 cam and head gaskets
New ls7 springs
Top piston rings gaped at .0028
Trick performance stg 3 front turbo kit
Precision turbo 74/75
80lb injectors
Walbro 450 in tank pump
Throttle cable tb
15 psi goal
4 l60e trans, 4l80e trans here for back up
Fan controls (Ac ;) )
Alky adding later
Ported and polished
heads
Sounds like it's COS5 time for the tune.
Have you been over to the EFILIVE forum??
Yes, I'm working through a cos3 tune now....I'm figuring it out now.....
Its harder than I thought.... Lol....big program to learn to operate.....
Thanks Chuck....how's your lsx project and are you going to BG?
Project is on hold...[Way too much time in the hospital.]:mad:
Was going to BG, but I've still not got much of my physical strength back, [lost 50#], to feel safe driving that far, by myself..
My bud is the east coast distributor of EFILIVE. He lives here in Atlanta, and is pretty knowledgeable. If you get hung up, maybe we can help.
I have to get busy and update my EFIlive program. We are putting a 525HP LS3 in a 62 Stude, and using the stock efi system!:D
I was hoping you were better....I can always come by and pick you up....
When you update , make sure you update the USB drivers, that was a big problem for Me....
The program is awesome, just a lot to learn....I'm getting it though.
Thanks for the offer, if I ever hit a brick wall, I'll let you know.....
Thanks again....
The truck is making stupid power on no timing and pig rich, low boost....I almost lost it already.....can't wait to get some times....
Thanks again....
Thanks for the offer. I doubt I could keep up w/ the pace, at this point. I don't go more than just a few minutes B4 I have to sit...Naps are frequent!
Sounds like some more tuning and the truck will be really SCARY!!
