here's a pic of my passenger-side header showing 1/8 NPT port placement. There's a port in each header tube plus the "usual" port near the turbo inlet. Driver-side is similar.
It can be very tricky selecting the right spot to weld the ports. The header should be mounted with all sparkplugs and wires in place, then mark the hole location. Measure 2-3 times, drill once!
I also advise to have the actual Theromouple (TC) probe onhand when marking holes, and make sure everything will clear. Don't forget to check clearance between the O2 sensor and the TC probe.
My photo shows the angled Autometer type-K probe, the skewed port locations were partly due to the probe fitting requirements. Note the heat shields for the sparkplug wires are still in place, that was another minor fit interference.
The #6 cyl probe is further from the flange than the others ... at the time, that seemed the best overall compromise to get everything to fit. All else being equal, the #6 probe might read lower temps, but I think a repeatable, relative temperature reading is probably as helpful as an absolute accurate temp.
I haven't actually used the headers yet, so no comment on how well the probes work :redface:
