Electrical issue?
larry33kc
I was mocking up my Scanmaster G and had everything wired up with a jumper wire from the fuse box to power it, and it fell and the wire touched my steering column and I heard a pop.
I now don't have any dash, dome, break lights or turn signals. I have checked the fuses and changed the one circuit breaker with know luck.
Anyone have any ideas?
I plugged it in this area.
Been there it pops one of the fuses. Sorry I don't remember what fuse but it's tied to one of them.
Sounds like a few different circuits are dead. It's possible you blew the fusible link down by the starter.
Those two BAT feeds are through the CIG-CLK fuse (20 A). If that one is good, then as Rick mentioned, took out a fusible link at the starter.
RemoveBeforeFlight
Hit both sides of the fuse socket with a test light to verify that circuit is dead.
There are 3 seperate links by the starter. One can blow while the others are still good. So only certain things will be effected depending on what one blows.
