1NASTYGN Active Member Joined Oct 7, 2009 Oct 5, 2017 #1 I noticed my new build does not have this. I am in the process of replacing the front cover with a TA. Attachments ImageUploadedByTapatalk1417161002.678738 (1).jpg 137.4 KB · Views: 118
pacecarta LOGGED OUT Staff member Joined Aug 1, 2003 Oct 5, 2017 #2 a long 1/4' bolt will have a section thats not threaded ..cut the head and threads off to make a cheap dowel
1NASTYGN Active Member Joined Oct 7, 2009 Oct 5, 2017 #5 Got it. Thank you all for the quick replies and DM!
juan89 Active Member Joined Oct 22, 2008 Oct 6, 2017 #6 GM used 1/4 inch hole and it requires, a smaller pin. A standard 1/4 inch dowel will be too tight.
M m233roller Banned Joined Jan 25, 2002 Oct 6, 2017 #7 True but Iv'e used them many times with no problem. A stock GM one is about 3ths. smaller.
pacecarta LOGGED OUT Staff member Joined Aug 1, 2003 Oct 6, 2017 #8 i always run a 1/4 bit though the crank sensor bracket
T turbofrank Well-Known Member Joined Nov 4, 2002 Oct 8, 2017 #9 Yes the one from hardware store is bigger grind it down a little.
