Engine Build
jpratt
I spun a rod bearing so I am having it rebuilt all together. 86 GN. I am not yet sure about the bore, if it has to be punched out or not so assume either way I guess for now. How does the following parts look for a street daily driven reliable car sound?
Walbro 340
36lbs injectors
ECM Street Chip
Red Armstrong Volt Booster
AFPR
Power Plate, Plenum
Billet Vaccum blcok
3"AT SS Turbo Down pipe
Thick core rad
ATR RP 313 B Cam
STock timing chain and cover
Blocked water drain percocks
new motor and trans mounts
Torque strap
throttle body block off plugs
custom brass body PCV 1 way check valve
160 Thermostat
These are all goin with a stock block, possible bored, stock replaced turbo, dual exhuast with 2 flowmaster's ( ATR SS 2.5 w/ Pitbulls later). These are the things that the builder suggested.
