Howdy,
The engine is starting to come together and I am now formulating the little details. Here's the combo so far:
Production 8484 4.1 Block with front 3 billet caps
Big valve home ported 8293 heads
twin IHI .48/.63 turbos
1.65 T&D's
72's and modded ECM
LS6 MAF and Trans+
TH400 with 1800/4200 switch pitch
3.07 rear gears
PAC Alky Kit
What I need advice on is in light of the weaker 4.1 block and the 3.07 rear gears I would like to make the power at as slow of engine speed as possible. What
1: Compression
2: Cam (Ductile Roller)
3: Fuel Pump (Walbro)
4: Any other tricks besides a girdle to make this thing more durable
Thanks,
1.65 T&D's
72's and modded ECM
LS6 MAF and Trans+
3.07 rear gears
PAC Alky Kit
1: Compression
Thanks,
