Apr 25, 2006 #1 T tomo64 New Member Joined Mar 24, 2006 Messages 8 I am changing my cam shaft ( #5 exhaust lobe and lifter is history) Do i need to remove the oil pump and water pump in order to remove the front cover? thanks tom
Apr 25, 2006 #2 conn84gn Well-Known Member Joined Jul 13, 2005 Messages 1,373 No you do not have to remove the water pump or the oil pump from the cover
Apr 25, 2006 #3 Jerryl Tall Unvaccinated Chinese Guy Joined Dec 14, 2004 Messages 9,641 conn84gn said: No you do not have to remove the water pump or the oil pump from the cover Click to expand... What he said. You do need to remove the cam sensor though.
