Engine is bolted to the trans, so will dropping engine temp help lower tranny temps?
V6UnderPressure
The Artist FKA Scott4DMny
Just a brainstorm. How much of a difference would lowering the engine temp make in lowering trans temp??? Thanks all!
Scott
That wouldn't change anything Scott. Its only attached by the bell housing of the tranny. The torque converter is hooked to the input shaft on the tranny and flywheel. A big tranny cooler in conjuction with a rad with stock provisions for tranny cooling are your best bet.
