IronEagle119
- Jun 16, 2001
Guys I just had my headgaskets replaced, and used the valve springs listed in the 86/87 common parts list on GNTType.org (Valve Springs, LT1 ~105# Seat Pressure 3927142[copied and pasted]). I'm having trouble with my engine. It builds boost fine when I give it light throttle, but when I give it more or make the rpms change suddenly it will loose all the boost it started to make and the rpms shoot way up and it seems to stop pushing the car and the engine is spinning freely. It doesn't do this all the time only when I get more aggressive with the throttle, I can build boost to 15 psi and it'll run like a champ too I'm soo confused. I can drive it easily and it will drive fine. Is this a possible wiped cam, I thought that these springs were ok to use since they were listed in that section of the web site without any warnings. If it is a wiped cam is it possible to change it without taking the heads off or do they have to come off to change the cam. If this is possibly something else let me know I'm kinda scared because I just paid $1100 worth of reapairs(head gaskets, rear main, valve seals, valve springs, control arms) on the car last week and I'm a college student that has a tight budget. I don't know much about engine building etc. If this is possibly something else I'm listening. If you guys need me to describe anything better I can try.
