Engine Rebuild part numbers
sdteb
trying to get it like you
Can anyone help out with a parts list for a basic rebuild with forged pistons..i have pulle what i can from gnttype but a more thorough list would be helpful to order parts from...i need what ever anyone can help with...first rebuild...thanks...
1. Push Rods - Comp Cams 8.65" PN = 7775-16. (if needed)
2. Valve Cover Gasket - Fel-Pro 0-84113-55384 (Pep Boys).
3. Crower Hi-Lube Lifters www.crower.com PN = 66053-3.
4. Cloye's Double Roller Timing Chain - PN = HP132C for .005 line bore, or HP132D for .010 line bore. ATR sells them.
5. Roller Bearing Cam Button - PN = SLP-MR-1874.
6. Billet Main Caps (optional, but stronger) from www.ramchargers.com PN = 518BUICKMAIN, and 518BUFRTMAIN.
7. TRW Forged Pistons - PN = TRW-L2481F-10 or -20 or -30 for overbore. I think you'll be hard pressed to find them in any size other than the .030 over.
8. Rings - Speed Pro plasma moly - PN = R10499-30 or Sealed Power File to Fit - PN = R10438.35 for a .030 over V8 set, allowing for 2 extras in case of over filing.
9. Main Bearings - Federal Mogul - PN = 107M.
10. Rod Bearings - Federal Mogul - PN = 6-3755APA.
11. Cam Bearings - Federal Mogul - PN = 1755M.
12. Federal Mogul High Volume Oil Pump Kit - PN = 224-518TP.
13. Federal Mogul Oil Pump Thrust Plate - PN = 224-518TP.
14. Fel-Pro Intake Valley Pan Gasket - (check local parts store)
15. ARP Rod Bolts - PN = 123-6002
16. ARP Main Bolts - PN = (call Summit or Jeg's for PN and ordering)
17. Rear Main Seal - Fel-Pro neoprene PN = BS-40613
18. Other gaskets - just ask your local parts store. Should be in stock.
Now, before you order any of this stuff, make sure you verify any tolerance changes, ie, line boring, cylinder bore, crank grinding, etc. Many of these part numbers require a suffix that designates the amount of size difference from the stock parameter.
However, this should get you started, and empty your wallet.
Best wishes in your endeavor!
crap
Now my dads car has a blown head gasket...anybody done the rjcracing.com head gaskets kit.....no luck this month...
