I am installing an 86-87 GN motor and tranny in my 87 cutlass and have a few questions but first my goals:
This is going to be a 98% street car run on 93 octane(might see the strip once or twice a year) and would like to be in the low 11's range if I was to put some slicks on. I already have a GN rear in my car with 3:42 posi and brand new suspension all over. A ton of people are telling me to install a 455 in my car but I kind of want something different. Anyway:
-I am going to install an in-tank pump in my 87 cutlass gas tank if possible. Do I need special lines because of the much higher fuel pressure of a fuel injection setup?
-Should I get the hotwire kit for the fuel pump? Should I get a volt booster kit?
-Will my Cutlass radiator work ok with this setup and will the hoses fit if I buy GN hoses?
-Where and how do I install a blow off valve, I read these are a necessary part of any high boost application because of the
-Is the Duttweiler neck for the intercooler a worthwhile upgrade or should I spend that money elsewhere?
-I heard the hardest part of this swap is wiring up the dashboard to work with this engine. Can anyone clarify what is actually hard and any ways to make it easier?
I will have more questions but thanks in advance for answers..
Joe
Joe
