Can't see your signature in taptalk. Can you post it
Works 6765bb G4,TurboSmart 40mm gate , 315 XTF front mount, Monroe 62mm t/b , worked Hemco,stock Champion ported intake, Weber short block (3.400 eagle crank, molnar rods, diamond pistons, steel caps), ported GN1's, Cometics (8.72:1), 212/206, 111, .523/.503 , T&D 1.6 rockers, Trend, TA exhaust manifs, TA front cover, Flow Kooler water pump, GN1 3" d/p, Turbosmart 40mm wastegate, 3" straight shot exhaust, 80#, injector hot wire, KB fpr , Alradco,TR6, ignition hot wire, MSD Superconductors,BAP, Racetronix 430 lph sender & hot wire, XFI, redundant grounds, Racetronix 8AN feed & 6AN rtn fuel lines, Janis forged trans,B&m trans clr,"Dusty" PTC 9.5" n/l,HR bar,HR dr si mount, boxed uprs & lwrs, (90/10) frt shocks,275/60/15 BFG's ,trunk braces,alum drums,s10 whl cyls,long shoes,weight loss program (car & driver), lots more changes in the pipe .
