boostmaster
- Aug 20, 2001
Well it's been a couple of weeks now since I took the 85 T on a high speed blast down a old back road. Had my girl with me and the car was pullin like a mother. Even though my boost setting was moderately low, 18psi on an 18* chip with xylene, on occasion my o2 volts had dipping dangerously low. I had run as much as 21psi before on pump gas and xylene with as little as 3-5* of KR. On my OTC scan tool for a split second I saw the o2 volts dip way low around .720mv and a huge spike in kr about 10-13kr head a little knock and backed off. Now many of you that have pit crew wives know that women are much more perceptive than men. And mine swore she heard something more sinister. Well got back to the house and noticed smoke coming out of the breather. Took a compression test and found all the cylinders except one had between 142-147psi. All except cylinder #5 wich was 107. Ah hah!! I thought blown head gasket. But i took it a step further and ran a leakdown test on bank 1-3-5 and I had 60% leakage in cylinder #1, 12% in #3 and whoa 100% in #5. Okay this could be good or bad, both cylinders w/ excessive blow bye into the crankcase. So I ordered a set off steel shim headgaskets and broke down the drivers side head. Low and behold no blown head gasket but on cylinder #5 about half way down there's a 1/8" dent almost into the water jacket. Well those steel shim headgasket sure are tough!!!, too tough!!!
