ESC hook up
blueta
Does anyone know what prongs go where with these? Like which is 12v-, 12v+,signal,and whatever else comes from it. I'm going to see if I can hook one of these up to my car (98 GTP) for use of a knock gauge.
Terminal B is the +12 fused switched IGN power.
Terminal C is the yellow/black output wire that goes to the ECM, signal out.
Terminal D is the ground.
Terminal E is the dark/blue single wire that goes to the actual KR sensor attached into the motor.
I don't see anything listed for terminal A.
I may be able to go look on the car for the actual connections etc. tomorrow.
So just hook up the ground, 12 volt, tap the blue one into the knock sensor and hook the yellow/black up to my home made gauge. Sounds simple. Just have some questions on the gauge itself on my other post. You've been a HUGE help, thanks!
